ELR Z1000R2 Blowing fuses
Grimreaper
#1 PostAuthor: Grimreaper » Fri Sep 04, 2020 7:55 pm
Hi folks, not long purchased a ELR Z1000R2, I have sorted out most of the problems but the fuse that works the neutral light, the rev counter and the fuel light. Any ideas ? Thanks Mike
CAT3
Re: ELR Z1000R2 Blowing fuses
#2 PostAuthor: CAT3 » Fri Sep 04, 2020 10:24 pm
You could try unplugging/disconnecting all those parts & see if the fuse still blows, (don't be tempted to fit a bigger fuse than what should be fitted).
If the fuse doesn't blow the fault is something to do with the items you have unplugged/disconnected.
Plug each back in, one at a time until you find the culprit.
You'll then need a wiring diagram & multimeter to go through the wires & try & find the short/defect.
weaver
#3 PostAuthor: weaver » Sat Sep 05, 2020 3:38 am
problems like this usually require properly tracing the cables for each component and examining them carefully,there will be a bare/loose wire somewhere that is shorting out.Take your time and you will find it.Good luck.
Grimreaper
#4 PostAuthor: Grimreaper » Sun Sep 06, 2020 3:55 am
Thanks for your help lads, I will get on it. Cheers Mike
Julian_Boolean
#5 PostAuthor: Julian_Boolean » Mon Sep 07, 2020 12:34 pm
Mine had a short in the right hand handlebar switch, blew the fuse as soon as the ignition was turned on, by a process of elimination I disconnected the handlebar switch and it stopped blowing fuses.
(Then I looked at the rest of the wiring, realised it was full of old repairs, so I made a new one)
