Tell me how this can be!!!
#1 PostAuthor: warren3200gt » Fri Oct 23, 2020 8:25 pm
someone asked me to take a look at their tacho issue. Bike is a 650 with points ignition. Tach is a straight 3 wire jobbie. Live, earth and signal.
As expected due to wasted spark tach reads 50% of actual revs. No problem I think, take a signal from both coils with diodes inline to stop feedback. Double the pulses equals double the reading I think. But no, it actually halved the reading further.
How the hell does that happen?
Re: Tell me how this can be!!!
#2 PostAuthor: kev edwards » Sat Oct 24, 2020 7:07 am
You've looked, foobared, now give it back, :biggrin , dark art is those electronics.
#3 PostAuthor: warren3200gt » Sat Oct 24, 2020 8:06 am
Kinda heading that direction Kev, alternatively, swop the pos and neg. It'll either work and double the reading or go bang. Etherway it would be a win. :D
needaz1100r
#4 PostAuthor: needaz1100r » Fri Oct 30, 2020 5:37 pm
warren3200gt wrote:someone asked me to take a look at their tacho issue. Bike is a 650 with points ignition. Tach is a straight 3 wire jobbie. Live, earth and signal.
Do the revs on the tacho increase as bike revs increase?
I've had to use one of these before.
https://www.ebay.com/itm/141931549970
Mark.
#5 PostAuthor: warren3200gt » Fri Oct 30, 2020 6:02 pm
Yes it does. Just confused about with one coil wired it halves the actual revs, which is to be expected, but with 2 coils connected i.e., doubling the pulses, it halves it even further. Made no sense.
However, after further investigation and adding a 1m ohm resistor inline not only did it smooth the pulse reading it corrected the double halving.
Kinda goes against everything I know about lectrickery which I admit isn't much!
