Alloy wheel refurb
Skid Mark
Alloy wheel refurb
#1 PostAuthor: Skid Mark » Sun Nov 01, 2020 2:57 pm
Hi All,
I have manage to steal a few hours here and there and started stripping the 1000r.
I am happy enough so far that there have been no major surprises and all bolts have come undone( with a bit of persuasion). I know this is the easy bit though. I am looking forward to selling off all the spare parts I'll have when I assemble it all later :lol: .
Anyway, The wheels were painted white well before I ever got it and I want to make sure they are worth the effort before I invest in them. I have no pictures at present but I will put them up when I get chance. The rear wheel had three of the wafer head allen bolts that hold on the disc drilled out and tapped to take a larger modified bolt, if this wasn't bad enough, on of these was held in with silicone!! I'm fairly happy to tidy up the threads and fit a bit of Aluminium rod drilled and tapped to suit the original bolts. Is there any other way of tackling this? The second issue is a small chip gone off the front wheel right were it meets the tyre. its about 8x4mm. Can I get this built in Aluminium weld( I'm guessing the wheel is a magnesium alloy) and would the heat effect the strength of the wheel?
Finally, I've rang around and while I can get the wheels powder coated pretty easily I haven't come across anyone who could anodize the wheels again.I am presuming when stripped the original colour will be gold, any suggestions how, or where I get this sorted?
Phil
Re: Alloy wheel refurb
#2 PostAuthor: Al » Sun Nov 01, 2020 4:52 pm
#3 PostAuthor: chrisNI » Sun Nov 01, 2020 5:34 pm
I’m not sure there is much magnesium in the R2 wheels any more than any other alloy wheel :shock: a picture of the chunk out might help if it’s not too bad a good alloy welder should be able to tackle it
needaz1100r
#4 PostAuthor: needaz1100r » Sun Nov 01, 2020 8:32 pm
chrisNI wrote:I’m not sure there is much magnesium in the R2 wheels any more than any other alloy wheel :shock: a picture of the chunk out might help if it’s not too bad a good alloy welder should be able to tackle it
No more than in a cylinder head...
head weld2.jpg (41.22 KiB) Viewed 4374 times
head weld3.jpg (50.13 KiB) Viewed 4374 times
head weld4.jpg (75.33 KiB) Viewed 4374 times
head weld5.jpg (49.46 KiB) Viewed 4374 times
head weld6.jpg (63.42 KiB) Viewed 4374 times
head weld7.jpg (42.9 KiB) Viewed 4374 times
head weld8.jpg (44.11 KiB) Viewed 4374 times
head weld9.jpg (44.92 KiB) Viewed 4374 times
head weld10.jpg (46.42 KiB) Viewed 4374 times
Mark.
needaz1100r
#5 PostAuthor: needaz1100r » Sun Nov 01, 2020 8:34 pm
cont...
head weld11.jpg (34.53 KiB) Viewed 4376 times
head weld12.jpg (38.9 KiB) Viewed 4376 times
Different one -
head weld.jpg (53.87 KiB) Viewed 4376 times
Mark.
needaz1100r
#6 PostAuthor: needaz1100r » Sun Nov 01, 2020 8:38 pm
Powder coating and diamond cutting...
I don't think the original wheels were anodised, I think they were painted then diamond cut, this is as close as I could get to Z1100R wheels gold...
Mark.
Skid Mark
#7 PostAuthor: Skid Mark » Sun Nov 01, 2020 9:18 pm
Thanks for the advice and link Al and Chris, I will post pics when I get back with camera, posting picture from my phone is painful.
Mark, if I could get the wheels looking like that I would be ecstatic! :D
P
needaz1100r
#8 PostAuthor: needaz1100r » Mon Nov 02, 2020 7:40 am
Skid Mark wrote:Thanks for the advice and link Al and Chris, I will post pics when I get back with camera, posting picture from my phone is painful.
P
Send them to me and I'll make you ecstatic, in a my wheels are lovely sort of a way of course.
PM me for details.
Mark.
Skid Mark
#9 PostAuthor: Skid Mark » Wed Nov 04, 2020 8:05 pm
Hi again lads,
Some pictures of the wheels. I have a broken circlip to remove and a botched retap to repair, then when the piggy bang allows I'll be sending the rims to Mark.
In the mean time any suggestions for stripping paint?
Mechanical or chemical?
I'm sure Mark can strip them, but I am itching to see what they are like underneath.
P
#10 PostAuthor: chrisNI » Wed Nov 04, 2020 11:02 pm
That chunk looks fixable. Blasting is probably easiest way to get paint off, soda if you want to get the edges polished.
#11 PostAuthor: Philippe » Thu Nov 05, 2020 4:08 am
Hi Skid Mark
I fear that the front wheel hit something and isn't straight anymore. Or did the chunk broke off when changing the tyre?
Wouldn't it be easier and cheaper to replace it with another wheel? They're not that hard to find after all. Or am I wrong?
You want to repaint them and the paint has to come off. Removing white paint or black paint is the same work...
Robw
#12 PostAuthor: Robw » Thu Nov 05, 2020 7:02 am
What size is the front wheel?
Rob
#13 PostAuthor: warren3200gt » Thu Nov 05, 2020 7:58 am
Philippe wrote:Hi Skid Mark
I too wouldnt want that fixed. It needs to be x rayed to ensure there are no unseen cracks from the impact. Much cheaper and simpler to source another un damaged one to re finish.
zapo
#14 PostAuthor: zapo » Thu Nov 05, 2020 9:46 am
+1 ...... that tyre damage to to left of the wheel damage suggests that the tyre has been "pinched" with the tyre then turning on the rim. That would be quite some force.
I see Zed people.
Gus
#15 PostAuthor: Gus » Thu Nov 05, 2020 11:13 am
I have a front and rear wheel which may be the same, if you would like some pictures I could put them up later?
Surplus to my requirements so very cheap.
Gus
"Set the GRINDER on it"
