Tampons fitted !!
pertonpc wrote:avoid running it up too often over winter unless actually going for a ride.
if you do run it try and get the silencers hot enough to encourage vapour to evaporate.
ensure the small drain holes underneath are unblocked and at lowest point for drainage (ie. not on side stand).
squirting some acf in drain holes and exit holes is not going to hurt.
warren3200gt wrote:I assume you have power where the bike is stored? If so try and make it as air tight as poss and stick a dehumidifier in there.
You'll be surprised how much moisture you'll extract.
