Backwards bolt?
Mark whiten
- new poster
Re: Backwards bolt?
For future reference , easy outs are very good . You drill a pilot hole and screw the easy out in which has a left hand spiral and this unscrews the broken off screw or bolt . Small good quality set less than a tenner
Blackseven
Re: Backwards bolt?
I have always found cheap easy outs can snap all to easily and leave a piece of hardened steel inside the sheared bolt. The methods outlined earlier in this post are much better options IMHO.
Re: Backwards bolt?
Blackseven wrote:I have always found cheap easy outs can snap all to easily and leave a piece of hardened steel inside the sheared bolt. The methods outlined earlier in this post are much better options IMHO.
+1.
Lemmy
Lemmy
Re: Backwards bolt?
Mr Bump wrote:Blackseven wrote:I have always found cheap easy outs can snap all to easily and leave a piece of hardened steel inside the sheared bolt. The methods outlined earlier in this post are much better options IMHO.
+1.
+2
- warren3200gt
Re: Backwards bolt?
Easy outs = devils spawn.
Re: Backwards bolt?
Well done that man, a little more advice don't buy your kitchen roll at M&S, you can get much cheaper anywhere else.
