Ignition switch for GPZ1100B1
JimBoUK
#1 PostAuthor: JimBoUK » Mon Dec 14, 2020 5:52 pm
Hi,
I have a US import GPZ1100B1.
The ignition switch is knackered and any key will turn it.
I’ve had a search for a new switch but none seem to be like mine.
It has the steering lock pin coming out from the bottom of the lock, not the side.
Any idea where I can get one or maybe it’s possible to dismantle it and fit a new barrel ?
Re: Ignition switch for GPZ1100B1
#2 PostAuthor: Al » Mon Dec 14, 2020 6:09 pm
Those switches are not very very much in demand and can be found everywhere. :D :D :D :D :D The other type, thats; not really much like it, will not fit but is available. It may be possible to switch the barrel over from one of the other type, but i really could not say. What i can tell you is that the electrical contact side of the switch is easily accessible and easily refurbished and they work well both electrically and mechanically when cleaned up well.
Edited :D
Robw
#3 PostAuthor: Robw » Mon Dec 14, 2020 6:36 pm
One on Ebay at the moment
JimBoUK
#4 PostAuthor: JimBoUK » Mon Dec 14, 2020 7:08 pm
RobW please could share a link or item number for the one on eBay.
I can’t find it
JimBoUK
#5 PostAuthor: JimBoUK » Mon Dec 14, 2020 7:24 pm
All I can find on eBay is this one from the states with the yolk and trip meter for $200 but with no key
https://www.ebay.co.uk/itm/Kawasaki-Tri ... 890.l49292
JimBoUK
#6 PostAuthor: JimBoUK » Mon Dec 14, 2020 7:34 pm
Robw
#7 PostAuthor: Robw » Mon Dec 14, 2020 7:34 pm
The one I saw was£120 and from Germany
#8 PostAuthor: z1bman » Mon Dec 14, 2020 10:00 pm
similar switch different block connector
https://www.ebay.co.uk/itm/NEW-1986-200 ... 3498402558
