rearset footpegs
rearset footpegs
Hello all.
I've been building a 'special' during lockdown but wasn't wanting to pay around £6-700 for japanese rearsets so have been designing some for myself on the 3D printer. Now I have them pretty much as I want them I'm talking to a few CNC machining firms to have them made.
Since the cost for one set is going to be ridiculous, I thought I'd gauge opinion on ordering several sets.
Without going into too much detail, I've designed these to accept readily available folding pegs and have mocked these up with whatever I had to hand. If there is a demand for them, I'll firm up an exact spec and can produce a ready to fit set, or just supply the levers, brackets and advice for you to assemble your own.
So, what do you think?
Chris.
Chris.
Re: rearset footpegs
Very clever stuff, love the brake side Not so sure about the gear leaver with its tall mounting bracket it does not look right IMHO.
Good work though would be in interested in the cost of the brackets themselves.
You’ve done a good job on those - I guess on a 900 you have to put the m/c somewhere, on a 1000 you can touch it in where the original was behind the side panel...
I'm with you on the long gear lever part. My first thinking was to cant the top of it in over the frame bracket to keep it out of the way of the inside of your boot, hence the height. I think the finished item will be about half as high so that the link rod runs alongside the frame bracket.
Regarding the mounting of the master cylinder, my intention was to free up the space behind the side panel for my electrics, rear shock remote reservoir, etc on my Z1000 as it has been mono-shocked. Also solved the Z900 problem.
I expect these would only be of interest to builders of modified zed's and i'm attempting to design a set which can work on 900's and 1000's. They may have a broader appeal if I made the reservoir mounting separate and bolted on so you could use it or discard it.
Thanks for the input guys. Appreciated.
As yet the CNC shops haven't come back with any prices so I'm still clueless as to how much they're going to cost but I'll post as soon as I know.
Looking cool do they use the original rear brake light switch ie the long spring on z1000 ????
Phil
Phil
International Rep
International Rep
Hello Phil, thanks.
No, for simplicity I've used a pressure switch. There is a tang coming off the inside of the brake lever which passes under the backing plate, used as a return spring locator and height adjuster which could be used to pull the standard brake light switch.
I should have some costings back in the coming days, but this may now be after Christmas / New Year.
I'd be interested in a set.
Interested in a price and spec
A brief update for anyone interested.
I've sent files to a number of CNC firms in the UK, Germany and China and am getting some answers and some questions back. I'm just refining what I expect will be the finished designs now.
I'm still open to constructive criticism on here so feel free.
At the moment i'm tending towards a black hard anodised finish. The gear rod actuator piece will be much reduced in height (thanks KwackerZ1), the scalloping out will be radiused in the corners. There can be a choice of footpegs depending on whether people want folding (in which case secondhand japanese stock parts seems an option as in the photos) or fixed. Either way, kickstarting won't be an option.
I should hopefully have an idea on cost as well as some more 3D models in about a week.
Very interested for a set.
- Z1streetfighter71
- ZedHead
My advice is to avoid China as they very likely will just copy your design and sell them for way less than you will.
10 years ago I put some designs out to Chinese companies for a product we were going to make and within weeks we saw the product for sale. They just ripped it off. And when we asked them about that they said they had and didn't care..
- Z1streetfighter71
- ZedHead
Ultim8pc wrote:My advice is to avoid China as they very likely will just copy your design and sell them for way less than you will.
+1 on that. Shipping prices have gone through the roof too. Leaving patriotism out of it, I'd be very inclined to use a uk supplier at the moment as supply chains are all to fu**.
Olly
Lemmy
Lemmy
Update coming soon.
Having taken on board your comments, I've made a few tweaks and will be re-sending the files to the manufacturers. I've found a company in Germany who seem good.
Watch this space.
Chris.
Watch this space.
Chris.
Users browsing this forum: Skid Mark and 31 guests
