powder coating stripping - anywhere near hertford anyone can recommend ?
#1 PostAuthor: chrisu » Wed Nov 11, 2020 9:34 am
as per title really - the wheels on my H are a horrible mustard yellow powder coat - I want them stripped so i can paint them the correct colour.
any suggestions ?
thanks.........
Stugill
Re: powder coating stripping - anywhere near hertford anyone can recommend ?
#2 PostAuthor: Stugill » Wed Nov 11, 2020 5:34 pm
Chris.
I used these about 5 years ago, very good and I would use them again. They are a decent size company and recall they weren't expensive.
Good luck.
Stu
http://www.amwblastcoat.co.uk/
#3 PostAuthor: chrisu » Thu Nov 12, 2020 9:47 am
cool. really close - thanks.
Hbrax1964
#4 PostAuthor: Hbrax1964 » Mon Jan 04, 2021 10:47 pm
Hi Chris,
Did you use those guys and if so how were they?
Im local and have a few parts need coating
Hugh
JimBoUK
#5 PostAuthor: JimBoUK » Tue Jan 05, 2021 2:45 pm
I’m planning on using them as well.
Got a big pile of bits to be stripped and powder coated for a GPZ.
I spoke to them and they said they have done many bike bits before. I said that I needed the frame number to show afterwards. The bloke knew exactly where I was coming from and said he could accommodate.
Only problem now is I’m not supposed to take the stuff down in the latest lockdown !
#6 PostAuthor: chrisu » Tue Jan 05, 2021 2:56 pm
Hi
Not yet. Got sidetracked then Christmas got in the way.
JimBoUK
#7 PostAuthor: JimBoUK » Tue Jan 26, 2021 7:08 pm
Just got some blasting and powder coating done a little way out of Hertford in Letchworth at Full Range Finishing Ltd.
There was a frame and 36 other pieces plus the frame needed a crack welding near the back.
Cost £275
I said the frame number needs to be visible as it’s a US import I still have to register. They just masked off the frame number so it got no coating. Not sure if that’s the normal approach.
There are 3 bits I’ve got to take back. The yolks are rubbish around the edges where the forks go through and one fork leg has a run.
Apart from that all good.
Stugill
#8 PostAuthor: Stugill » Wed Jan 27, 2021 12:00 pm
That seems like a good amount of work for the money. Was it all powder coated?
Stu
JimBoUK
#9 PostAuthor: JimBoUK » Wed Jan 27, 2021 12:52 pm
Yeh Stu.
Took them a pile of 37 tatty pieces and got it all back as shown in the pics.
Went back today with the 3 bits that were not right. They apologised and said they will be sorted by the end of the week. Bit sloppy though they even gave them back to me like that.
Stugill
#10 PostAuthor: Stugill » Fri Jan 29, 2021 9:38 am
Cheers.
Stu
Users browsing this forum: Google [Bot] and 36 guests
