Hi,
Can anyone help me with the brake joint bolts:
1x 110N0632, bolt hex head
1x110N0640, bolt hex head
John Brookes restorer's guide says that they should be chrome finish.
searching brake joint bolts
Re: searching brake joint bolts
Hi mate,
Re pic attached. The smaller (dirtier!) bolt may be a 110N0632. It is an original from my Z1-B (build date Jan 1975) and is an M6 x 32mm. The other newer one is a generic M6 x 40mm.
You are welcome to one or both if you can't track them down.
Z1-B, 360bhp ZX1000NGF
steve452 wrote:Hi mate,
Steve I will sent you an PM.
ADRIAN H wrote:Have you tried asking ZPower - if anyone can get them they can.
https://www.z-power.co.uk/
Hi Adrian,
Thanks for the suggestion! I've sent Steve a message about his offer.
Hodna still do a decent range of chrome plated bolts in M6, M8, etc. They are without markings on the head so could be good for other marques.
An example part number would be 92101060350B which is 6x35.
It may help if you can’t find the genuine Z items.
Regards
Regards
r3sc wrote:Hodna still do a decent range of chrome plated bolts in M6, M8, etc. They are without markings on the head so could be good for other marques.
Regards
Thanks!
I forgot about this website. They got a lot of Hodna bolts!
https://honda4parts.nl/index.php?ceid=4 ... 513b3f0cc6
You can always try Dave Silver Spares in the U.K. They stock a lot of Hodna parts, including the bolts.
