Cam cap bolt torque
steve452
Cam cap bolt torque
#1 PostAuthor: steve452 » Thu Jan 21, 2021 5:15 pm
The SM (Revision 3 Jly 74) specifies the torque for the cam cap bolts as 13.5 ft/lb (1.5 kg/m) which I am guessing is a conversion error as 1.5 kg/m is actually about 10.85 ft/lbs. I have just reinstalled the cams and torqued the cap bolts up to 1.5 kg/m (ie the lower of the two settings).
Before I replace the cam cover can someone please confirm whether this is correct, or should I go for the higher setting of 13.5 ft/lb (which is about 1.87 kg/m).
Many thanks in advance guys.
Z1-B, 360bhp ZX1000NGF
Re: Cam cap bolt torque
#2 PostAuthor: chrisNI » Thu Jan 21, 2021 5:47 pm
Cam cap bolts don't need more than 6-7ft lbs the factory manual is wrong and 13.5 will kill them :shock:
#3 PostAuthor: z1bman » Thu Jan 21, 2021 6:05 pm
8.7 ft pounds
steve452
#4 PostAuthor: steve452 » Thu Jan 21, 2021 7:13 pm
z1bman wrote:8.7 ft pounds
That's near enough (-0.05 ft/lb) to 105 in/lb which is what the manual recommends for the cam cover bolts! Should the cam cap bolts be the same?
Mine are already torqued to 10.8 ft/lb. Here's hoping they stay there!
#5 PostAuthor: z1bman » Thu Jan 21, 2021 7:36 pm
yes they are the same torque as cam cover bolts
#6 PostAuthor: ADRIAN H » Thu Jan 21, 2021 8:05 pm
z1bman wrote:yes they are the same torque as cam cover bolts
+1 correct torque is 8.7 ft/lb.
#7 PostAuthor: kev edwards » Thu Jan 21, 2021 8:11 pm
My factory manual gives 7.9 to 9.4 foot pounds, i always go to the lower reading.
steve452
#8 PostAuthor: steve452 » Fri Jan 22, 2021 8:57 am
Would it be a good idea to loosen off the bolts and then re-torque to the correct figure?
Mr Bump
#9 PostAuthor: Mr Bump » Fri Jan 22, 2021 11:57 am
Basically 10 nm in new money, which is DIN standard for an 8.8 grade bolt.
Olly
Lemmy
Mr Bump
#10 PostAuthor: Mr Bump » Fri Jan 22, 2021 12:02 pm
steve452 wrote:Would it be a good idea to loosen off the bolts and then re-torque to the correct figure?
Wouldn't hurt, the head may distort very slightly if the bolts are too tight, certainly seen this with the main head studs. Also if I'd damaged a thread or stretched a bolt I'd rather find it this time of year than in summer when I want to ride it, though usually if you've damaged something it'll be obvious at the time as it'll just keep on turning.
Olly
Lemmy
steve452
#11 PostAuthor: steve452 » Fri Jan 22, 2021 12:08 pm
Cheers Olly. They did seem to tighten up fine without any of the "slippage" you normally get when a bolt threads. However I think I'll err on the side of caution and re-torque them.
steve452
#12 PostAuthor: steve452 » Fri Jan 22, 2021 4:37 pm
Cam cap bolts now torqued up to 8.7ish ft/lb, chain tensioner installed and adjusted and engine rotated by hand a couple of times and the cam timing is still the same! Result!
Quick question and possibly bollocks but I'm sure I read in a past post here that there is a correct orientation for the cam cover. It looks symmetrical to me apart from the "Made in Japan" stamping inside the central bit covering the tunnel, but I stand to be corrected if I'm wrong.
#13 PostAuthor: kev edwards » Fri Jan 22, 2021 7:19 pm
Some covers have an arrow inside some don't, the one on my thou fits both ways.
#14 PostAuthor: ADRIAN H » Fri Jan 22, 2021 10:00 pm
kev edwards wrote:Some covers have an arrow inside some don't, the one on my thou fits both ways.
+1 arrow points forwards
Keefleaf
#15 PostAuthor: Keefleaf » Sat Jan 23, 2021 2:12 pm
chrisNI wrote:Cam cap bolts don't need more than 6-7ft lbs the factory manual is wrong and 13.5 will kill them :shock:
Are the torque values correct in Club Year Book ?
