1100 unitrack
1100 unitrack
I'm looking for two of the bearing sleeves for the rear suspension rocker arm.They're nla , i could get steel ones made but the originals are case hardened. Cheers.
Re: 1100 unitrack
Hi zippy
I know what you're saying. I encountered the same issue. If you have a lathe yourself or if you know someone who has a lathe you can use a rod of "cemented" steel of 20 mm diameter. The outside of that rod is hardened but the inside of rod can be machined, drilled out in order to make a replacement part.
If you google "cemented steel" you can find a supplier in the UK I guess ...
Good luck
Good luck
Re: 1100 unitrack
Thanks Philippe, can't find anything like that in the UK though.
Re: 1100 unitrack
Think i'm sorted now Gus. Thanks for the offer mate.
