tank cleaning
keith mayall
tank cleaning
#1 PostAuthor: keith mayall » Thu Feb 25, 2021 12:11 pm
guys I've scrolled through the site for a good tank cleaning method ,ive got 2 tanks z1000a1s ,that have just been painted[which took 6 months] so inside is now filthy.What do you guys recommend,I like the coke and harpic idea but don't know how much ratio harpic to coke,theres rust in the tanks so I will need to get that out as well, not a lot mostly surface rust.I know its been on here before but there's no ratios and types and a layman terms to do it.cheers.
Re: tank cleaning
#2 PostAuthor: Bill P » Thu Feb 25, 2021 1:15 pm
I just use vinegar if its not heavy rust :)
keith mayall
Re: tank cleaning
#3 PostAuthor: keith mayall » Thu Feb 25, 2021 1:54 pm
white vinegar,,how much do you put in.
marmck
Re: tank cleaning
#4 PostAuthor: marmck » Thu Feb 25, 2021 2:37 pm
In the search box, search tank cleaning ,plenty of tips there , :D
Stugill
Re: tank cleaning
#5 PostAuthor: Stugill » Thu Feb 25, 2021 8:21 pm
It's a 3:1 coke to harpic mix, I used Harpic Max power plus, and cheap full sugar coke not diet.
Good luck
Stu
Re: tank cleaning
#6 PostAuthor: Ultim8pc » Fri Feb 26, 2021 12:00 am
40% Phosphoric acid
keith mayall
Re: tank cleaning
#7 PostAuthor: keith mayall » Fri Feb 26, 2021 8:26 am
I did the phosphoric acid last year, but got flash rust even though I rinsed and put meths in.not wanting to try it with tanks being freshly painted.gping full fat coke route this time.
Paulb
Re: tank cleaning
#8 PostAuthor: Paulb » Sat Feb 27, 2021 10:56 am
I Swear by undiluted cider vinegar !
Z900A4.
Ducati Streetfighter V4 S
Re: tank cleaning
#9 PostAuthor: Ultim8pc » Sat Feb 27, 2021 10:28 pm
keith mayall wrote:I did the phosphoric acid last year, but got flash rust even though I rinsed and put meths in.not wanting to try it with tanks being freshly painted.gping full fat coke route this time.
If it flash rusts you haven't left it long enough..
Throckley Lad
Re: tank cleaning
#10 PostAuthor: Throckley Lad » Sun Feb 28, 2021 8:40 pm
I have used DEOX-C to great effect - cleaned my wife's CBR125 tank perfectly, and it was very bad, including the fuel pump. Used WD40 then 2 stroke mix to keep it from re-rusting until we could fill it with Petrol. This stuff works well on all rusty parts.
