Early Z1 arrives in N. Wales.
MrDavo
Re: Early Z1 arrives in N. Wales.
#16 PostAuthor: MrDavo » Thu Feb 25, 2021 3:05 pm
I need to find a source of genuine OEM bands. Mine are new, from a well known specialist, but black. When I queried it I was told that that's all that's available :( I couldn't get Cradley's website to go back that far to check if they have them.
A quick query about the hose feeding oil to the chain oiler, I've never seen one on the outside of the transmission cover before. That said I can see that keeping it away from the drive chain is an issue, very messy if the chain cuts it. Although I have the original tank and pump for my Z1A, I won't be fitting it because my side panel came painted, with no hole for the dipstick, and I daren't cut a hole in case I screw up the paint.
1974 Z1A
1969 H**** CL450 ‘Scrambler’
2005 H-D XL1200R Sportster
TZ750D
#17 PostAuthor: TZ750D » Thu Feb 25, 2021 4:08 pm
If you enter the OEM part number in the search box on Cradley Kawasaki website, it will come up if they have it. Price was good too £8 each delivered. Also the appearance is correct - dark olive. Sometimes the big 4 manufacturers use modern replacements (like for tubing) which dont look the same as the original part, even though the part number is the same and its an OEM part.
I just bought some for my H2C, part number 92037-061 (front and rear carb rubber clamps) - the Z1 part may be different - I haven't checked.
MrDavo wrote:I need to find a source of genuine OEM bands. Mine are new, from a well known specialist, but black. When I queried it I was told that that's all that's available :( I couldn't get Cradley's website to go back that far to check if they have them.
Regards,
Don
#1410
MrDavo
#18 PostAuthor: MrDavo » Thu Feb 25, 2021 4:58 pm
The H2 part is the same number as the superceded number for the Z1, however I drew a blank at Cradley. It looks like you got the last ones, it shows as no longer available.
I will keep trying but I'm only interested in the real thing. Most listings turn out to be for a compatible part, probably the black coated replicas I got. I found some in the USA on eBay, but the postage is mental as you'd expect.
1974 Z1A
TZ750D
#19 PostAuthor: TZ750D » Thu Feb 25, 2021 5:19 pm
Go to this URL
https://www.kawasakioriginalparts.com
And enter the part 92037061 in the search box on left hand side
They come up as in stock and orderable. I just tried it - they have plenty in stock at £5.98
I agree overseas stuff is crazy prices now.
MrDavo wrote:The H2 part is the same number as the superceded number for the Z1, however I drew a blank at Cradley. It looks like you got the last ones, it shows as no longer available.
Regards,
Don
#1410
MrDavo
#20 PostAuthor: MrDavo » Thu Feb 25, 2021 5:54 pm
Ordered and paid for, thanks!
I'm not sure why their main website drew a blank, the link you gave me worked a treat though - bookmarked for future use. :)
1974 Z1A
zeddie
#21 PostAuthor: zeddie » Wed Mar 10, 2021 11:47 pm
Always nice to see another Z1 in North Wales, I live on the coast not too far from you so hope to catch up some time during the coming months.
TZ750D
#22 PostAuthor: TZ750D » Thu Mar 11, 2021 4:38 am
Definitely- thanks Zeddie
zeddie wrote:Always nice to see another Z1 in North Wales, I live on the coast not too far from you so hope to catch up some time during the coming months.
Regards,
Don
#1410
