Speedo and tacho foam
Gavin
#1 PostAuthor: Gavin » Sat Mar 13, 2021 11:25 pm
Can anyone tell me the thickness of the foam that the clocks sit on, also is there a particular type I should be getting or will neoprene do.
Gavin
Z1000 MK2
Z1300 DFI
tlc
Re: Speedo and tacho foam
#2 PostAuthor: tlc » Sun Mar 14, 2021 3:31 pm
I searched old posts but I think it got lost in the great database wipe.
I had some foam from a supplier in High Wycombe which I made into several kits and then gave away.
I think I have a little left but not cut to size. As far as I remember it was 6mm Toshiba foam. Buggered if I can find it now.
tlc
#3 PostAuthor: tlc » Sun Mar 21, 2021 8:25 am
Found it.
Let me know if you or anyone else wants some.
popsA1
#4 PostAuthor: popsA1 » Sun Mar 21, 2021 1:16 pm
Yes please. I couldn’t believe the state of mine when I last looked.
I’ve been hoping to find something suitable for some time.
A2 1979-80. A1 1980-now
hartyb
#5 PostAuthor: hartyb » Mon Apr 05, 2021 6:43 pm
I am also in the market for some
Remember your original post now
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
BJ81ZED
#6 PostAuthor: BJ81ZED » Fri Apr 09, 2021 1:00 pm
I would take some too for my 1100ST, same as 1000J clocks. They do move even though nuts are tight, might solve it.
1981 Z1100ST
2003 ZZR1200
1999 4.6 Range Rover P38
1925 Marshall S Type Steam Roller
Previous Zeds: 1000J Pip Higham special, GPZ750 unitrack, Z650B and one non-Zed ZZR600
8 Valve Mark
#7 PostAuthor: 8 Valve Mark » Fri Apr 09, 2021 2:40 pm
BJ81ZED wrote:I would take some too for my 1100ST, same as 1000J clocks. They do move even though nuts are tight, might solve it.
the J clocks are designed to have a bit of "suspension" to protect the electronics from vibration. bloody annoying, but true.
