Z 1000 St E2
Dunlop4
Re: Z 1000 St E2
#91 PostAuthor: Dunlop4 » Sat Apr 10, 2021 1:06 pm
First start up successful.
The ignition needs setting up, it is a boyer bransden and some new fuel pipe.
Dunlop4
Re: Z 1000 St E2
#92 PostAuthor: Dunlop4 » Sun Apr 11, 2021 1:17 pm
I removed the Boyer Bransden and refitted as per instructions. It says to set the full advance at 5000rpm, with a strobe.
I will get a couple of hundred miles on the engine first.
The startup went a lot smoother this time. It cannot be far off.
Re: Z 1000 St E2
#93 PostAuthor: Pigford » Sun Apr 11, 2021 5:38 pm
Dunlop4 wrote:I removed the Boyer Bransden and refitted as per instructions. It says to set the full advance at 5000rpm, with a strobe.
Just set it at the stated 5000 rpm now - that won't do any harm in a fresh motor, especially as it won't be under load, wrong ignition timing is more damaging.
Looks good by the way!
Dunlop4
Re: Z 1000 St E2
#94 PostAuthor: Dunlop4 » Sat Apr 17, 2021 9:23 am
Checkin torqe settings for mot Monday. Rear spindle was in wrong way round.
Have corrected this, working my way through rest of bike.
Re: Z 1000 St E2
#95 PostAuthor: chrisNI » Sat Apr 17, 2021 10:43 am
Bike’s looking great interested to see it finished :D
Avon ST
Re: Z 1000 St E2
#96 PostAuthor: Avon ST » Sat Apr 17, 2021 12:13 pm
Ready for mot and first ride, has anyone the tyre pressures.
Avon ST
Re: Z 1000 St E2
#97 PostAuthor: Avon ST » Sat Apr 17, 2021 12:16 pm
Side stand leaning over to far
Re: Z 1000 St E2
#98 PostAuthor: Philippe » Sat Apr 17, 2021 3:28 pm
Hi Avon ST and Dunlop 4
according to the shop manual:
front: 2,00 Kg/cm² or 28 psi
rear: 2,25 kg/cm² or 32 psi up to 97.5 kg, (load)
2,50 kg/cm² or 36 psi between 97,5 and 165 kg (load)
2,80 kg/cm² or 40 psi between 164 and 193 kg (load)
Dunlop4
Re: Z 1000 St E2
#99 PostAuthor: Dunlop4 » Sun Apr 18, 2021 9:47 am
Thanks Philippe.
Dunlop4
Re: Z 1000 St E2
#100 PostAuthor: Dunlop4 » Mon Apr 19, 2021 4:11 pm
Passed mot, fork seal starting to leak.
Re: Z 1000 St E2
#101 PostAuthor: Philippe » Mon Apr 19, 2021 4:23 pm
Hi Dunlop 4
congratulations that your bike passed the MOT.
Are you sure that the fork stanchion has no pitting, that causes the fork seals to leak, even after a short time.
Hope you can find a solution for it and that you can enjoy your ST.
Dunlop4
Re: Z 1000 St E2
#102 PostAuthor: Dunlop4 » Sun May 02, 2021 6:58 pm
Took the ST for another shake down run today, up to 400miles. Engine starting to loosen up.
Oil is leaking from the top of one of the fork tops.
Re: Z 1000 St E2
#103 PostAuthor: paul doran » Mon May 03, 2021 11:32 am
Cracking looking bike
These are so under rated as a Zed
Really pull well and look the part
MikeP
Re: Z 1000 St E2
#104 PostAuthor: MikeP » Mon May 03, 2021 12:47 pm
Agree with Paul, they're an under-rated Zed.
Unfortunately had to sell my Z1000ST at the weekend as it wasn't being used, and I need the space for another Kwaki project.
She's a lovely ride and I'm sure the new owner will enjoy her.
Dunlop4
Re: Z 1000 St E2
#105 PostAuthor: Dunlop4 » Mon May 03, 2021 5:46 pm
Yes i agree a very underrated zed.
Mike was your ST a UK bike and are the handlebars standard?
