Z1000A project
Johno23
Re: Z1000A project
#31 PostAuthor: Johno23 » Fri Feb 26, 2021 8:27 am
Ultim8pc wrote:
Johno23 wrote:Another question for you guys( probably many more to come!)
I’m just going through everything from the broken down bike. The ignition on the bike was a Boyer, what do you guys think of these? Also I have no ignition advance unit on the bike as I believe the Boyer doesn’t need it. If I fit a Dyna ignition does that need the original adv unit to run the ignition, I’m sure I’ve seen one on a 900 with the unit still in place.
Dyna S just replaces the points and keeps the advancer.
The Dyna3/Pro/2000 replaces the advancer and does that electronically.
I have a very tidy, but working Dyna3 system for sale if you have interest.
Yes, may well be interested in that, how much are you looking for it?
Edit: Don’t worry I already know and have bought it off you! :D
Johno23
Re: Z1000A project
#32 PostAuthor: Johno23 » Sun May 09, 2021 2:55 pm
Stripped down the forks today. The dampers are different but only in the shape of the top bit. Does this matter as I can’t see what difference it would make to have two the same. Also, do I need to change the piston and that orange washer?
