Can anybody tell me the correct size of washer for the cylinder head ?
Is there any issue replacing the zinc plated steel with stainless steel ?
Thanks Steve
Cylinder Head Washers
- wheelysteve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Cylinder Head Washers
Do you mean the 92022-215 10mm washers? I thought they were copper.
Z1-B, 360bhp ZX1000NGF
- wheelysteve
The copper ones are for the 4 outer studs where oil is fed under them, i.e. they are a seal. The others are steel. However, I'm working on a Z650 head which has the same size washers but they are all steel.
The originals are not standard 10mm washers I believe, but are a bit wider....around 22mm vs the std 20mm
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Not sure if this helps but there is a description further down detailing the washer size as 22mm x 10.5mm x 1.6mm and claiming that they are to original spec.
https://www.ebay.co.uk/itm/392235416444 ... 3d0c4f026e
A bit unsure exactly which washers you are talking about & on exactly what engine ?
On the Z900's the 10mm capped nuts should all have copper washers on. They should either be renewed or at least annealed before refitting the nuts.
The two 6mm bolts, on the outside of plugs 1 & 4 have no washers fitted.
Z650B2 OEM - 22mm OD, 10.5 ID x 1.5mm - Zinc plated
- wheelysteve
Thanks Adrian.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
