Replace Ignition Key Switch
Hi i have swapped out the steering lock and seat lock from the 3 new items i purchased from Z Power. does anyone have a simple step by step guide for replacing the ignition switch please?
Bike now finished what a joy!
Re: Replace Ignition Key Switch
Hi Wayne1960
for what kind of model ? Z1 or Z900A4 ? or Z1000 ?
Hi Philippe i hoped you might answer.
Its a 1976 Z900 A4
Its a 1976 Z900 A4
if you remove or lower the headlight bowl (take off the light unit and remove 1 of the indicator stems. this gets you more room.
remove idiot light cover.
disconnect ign switch
unscrew round black plastic bit from top of switch.
drop switch out from the bottom
refit in reverse.
refit in reverse.
Perfect thanks
Hi Wayne
I was too late to check your answer...
Chris was faster !!!
Just do it as he says, I couldn't do it better.
Ok the inevitable happened and the wires in the male plug came out leaving only the white attached!
How do i connect the wires back into the male brass pins!
new plug with new pins is what i'd do - try vehicle wiring products or bikerstoolbox
Ok new plug fitted and all good. well nearly! the neutral light decided to play up and doesn't come on
checked in neutral
checked lamp with new and the lamp is ok
checked the 2 wires brown and red/green and they look ok
is it something simple?
checked in neutral
