Terminal type?
sharpeyie
Terminal type?
#1 PostAuthor: sharpeyie » Wed Oct 20, 2021 10:22 pm
Hi all.
Can anyone tell me what the trade name/manufacturer (or whatever they’re known as) of the round-pin crimp terminals in the multi-pin connectors on a Z1 loom? As close as I can gauge they’re around 2mm dia.
Whilst you’re there does anyone know how they anchor into the connector (and crucially how to get them out?)
Thanks.
Stewart.
Re: Terminal type?
#2 PostAuthor: z1bman » Thu Oct 21, 2021 8:10 pm
you mean these? if so send them a sample
https://kojaycat.co.uk/epages/950000457 ... N-MAL-TERM
Mjay
Re: Terminal type?
#3 PostAuthor: Mjay » Mon Oct 25, 2021 9:38 pm
Regarding the removal of the individual cables from a typical multi pin electrical connector.
I had to do this when restoring my Suzuki GT750. If you look inside the body of the connector you can see the spade connectors, each spade has a tiny retaining ‘tang’ which protrudes up from the spade.
If you use a fine jewellers screwdriver (or similar item) you can depress the tang and simply slide the wire out of the connector block.
Refitting each cable is really easy, just slide the cable back into the connector and the tang will click into place again.
Suggest that you take a digital image of the connector block prior to removing any cables just so you can replace them in there correct locations.
I have tried to take an image of the inside of the connector as fitted to my Z1000. It was difficult to focus but I think you can see the small tangs. You may need to zoom in to see things a bit clearer.
Hope this helps.
KeithZ1R
Re: Terminal type?
#4 PostAuthor: KeithZ1R » Tue Oct 26, 2021 7:18 am
Or you could just get a set of these from Bikerstoolbox remember to let Ralph know your a PUM for a discount :up
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
sharpeyie
Re: Terminal type?
#5 PostAuthor: sharpeyie » Thu Oct 28, 2021 7:33 pm
Thanks for your help guys.
I think I am going to have to sacrifice one or two to find out the crimp type definitively and then should be able to figure how to remove them. Definitely sending a sample to Kojacat is the answer.
Thanks again.
z2.john
Re: Terminal type?
#6 PostAuthor: z2.john » Fri Oct 29, 2021 6:46 am
This guy is the closest you will find for your needs.
http://www.vintageconnections.com/
rickm
Re: Terminal type?
#7 PostAuthor: rickm » Fri Oct 29, 2021 10:05 am
KeithZ1R wrote:Or you could just get a set of these from Bikerstoolbox remember to let Ralph know your a PUM for a discount :up
I couldn't find these on the web site.
Can you post a direct link?
H2B GPZ900R
KeithZ1R
Re: Terminal type?
#8 PostAuthor: KeithZ1R » Fri Oct 29, 2021 11:56 am
Ah mebe he does not sell them pretty sure he did :?:
You can get them here
https://www.vehiclewiringproducts.co.uk ... h=terminal
Keith
:bop :gom
mistaken.
sharpeyie
Re: Terminal type?
#9 PostAuthor: sharpeyie » Mon Nov 08, 2021 11:40 am
z2.john wrote:This guy is the closest you will find for your needs.
Wow that’s pretty comprehensive. I think I see what I am looking for. Thanks for that.
