Hello. I need a set of J barrels for my project. I will be boring them out so a LITTLE damage is nothing to worry about.
They are going into an 1100 block with 1070 hi comp pistons Then squeezed into a Z650 frame.
Ta.
998cc barrels
- warren3200gt
Re: 998cc barrels
Might be able to help you out in a month or two. Doing the opposite putting 1100 top end on a 1000 bottom end so assuming all is OK the 1000 block will be superfluous to requirements.
By Brands Hatch.
By Brands Hatch.
Spamwood999
- new poster
Re: 998cc barrels
Yes please.
I will have an 1100 top end if you are interested.
Near Margate.
Near Margate.
- warren3200gt
Re: 998cc barrels
OK, your name is on it. Barrels have a bit of surface rust but if your boring it it shouldn't be an issue. The whole bike was dismantled when I got it. I have pistons,rings and head also if you need them.
Cases are split at the moment cleaning them up. Awaiting gasket and seal sets from zp before I can rebuild it and check out if the 1100 conversion is good. Assuming all is good your name is on the 1000 set.
Spamwood999
- new poster
