Piston ring compression tool
harri183
#1 PostAuthor: harri183 » Sun Feb 27, 2022 9:05 am
Anyone got the z1000 piston ring compression tool for sale rent loan postage paid post ways plus something for your time. Tried zip ties and bits of bottles don’t want to do any damage by pressing on. Cheers
Re: Piston ring compression tool
#2 PostAuthor: ADRIAN H » Sun Feb 27, 2022 8:57 pm
Ralph a member / area rep on here runs this website and listed under engine build tools is piston ring compressing clamps (also a video on site showing them being used) - I think you’ll need 2 sets - just under £20 each. If you’re a paid up member you should get a discount.
https://www.bikerstoolbox.co.uk/
harri183
#3 PostAuthor: harri183 » Tue Mar 01, 2022 6:48 pm
malc87
#4 PostAuthor: malc87 » Tue Mar 01, 2022 6:57 pm
Ive got the one for the z1.Is that what you need?
harri183
#5 PostAuthor: harri183 » Tue Mar 01, 2022 8:03 pm
Think there is two z1 z900 and z1000 I need it for my z1100 which I would think would be the z1000 one. After speaking to Kawasaki U.K. the 1100 uses a completely different tool altogether, they said they are obsolete I have found one at a cheap price but will have to wait and see what turns up as no one could confirm it’s the same but. Cheers
rickm
#6 PostAuthor: rickm » Wed Mar 02, 2022 10:55 am
Don't know how others on here have faired, but I've rebuilt a few 4 cylinder engines without using a ring compression tool. If the liner has plenty of chamfer on it and you're careful and don't mind losing the odd bit of fingernail you can refit pistons without a ring compression tool.
As above, others may advise against this but I've always managed it without breaking a ring yet.
H2B GPZ900R
#7 PostAuthor: warren3200gt » Wed Mar 02, 2022 11:28 am
Rebuilt literally dozens of engines. Never found the need to use one either. Worst lengths I've had to go too is a plastic strip / cable tie combo.
harri183
#8 PostAuthor: harri183 » Wed Mar 02, 2022 12:38 pm
First time doing a 4 cylinder and just don’t want to damage anything. Will give it another go.
