Starter/clutch switch
Skid Mark
#1 PostAuthor: Skid Mark » Fri Mar 18, 2022 4:37 pm
Not sure of the correct name for this. Its the 'dead man' type switch at the clutch that prevents the starter turning if the clutch is not pulled in.
Mine was bodged with chemical metal before I disassembled the bike. I currently have it by passed with a jumper in the connector. Does anyone have a switch suitable for a ELR or J? I just need the switch and two wires but may consider the whole switch gear if someone doesn't want to split a set.
P
Re: Starter/clutch switch
#2 PostAuthor: z1bman » Sun Apr 10, 2022 9:13 am
Skid Mark
#3 PostAuthor: Skid Mark » Sun Apr 10, 2022 11:34 am
z1bman wrote:https://www.ebay.co.uk/itm/275259315280?fits=UKM_Make%3AKawasaki&hash=item4016bbd450:g:Cs8AAOxyUrZS4njr
Thanks Z1b man,
The drop down menu says its not compatible but at a tenner it is worth a punt.
#4 PostAuthor: z1bman » Sun Apr 10, 2022 5:37 pm
it will fit trust me. on the z1000r1 the clutch switch is part of the l/h switch on most other models it is a seperate part
Skid Mark
#5 PostAuthor: Skid Mark » Sun Apr 10, 2022 6:20 pm
z1bman wrote:it will fit trust me. on the z1000r1 the clutch switch is part of the l/h switch on most other models it is a seperate part
I will ( trust you).
P
