Identify this Ignition?
richardwilson45
#1 PostAuthor: richardwilson45 » Thu Apr 21, 2022 8:38 pm
Hi Guys, just getting to the end of my Z750 engine build, and horror! I cannot find the ignition puck-ups or advancer / governor.
I did find my spare Z1000 MK2 set, a new ZX11 set and half a dozen IC Igniters, and a set that I cannot identify. They are not Kawasaki made, but fit the 750 cases. They are curiously only two wires? Any idea what make they are and whether I can rig them up to a Kawasaki igniter box?
Re: Identify this Ignition?
#2 PostAuthor: z1bman » Thu Apr 21, 2022 9:02 pm
they are Suzuki gs750 / 850
richardwilson45
#3 PostAuthor: richardwilson45 » Fri Apr 22, 2022 5:59 am
Thanks for that,
How odd.
I'm building the 750 motor from 5 engines that were put in store with another bike shop.
They were disassembled 35 years ago, by some helpful git and so I have crates full of parts all mixed up.
It appears that they robbed various bits and in some cases replaced with others.
The one bit I didn't check for before I started to build was the pick-ups!
Anybody got any pick-ups and advancer for a 750L3 / R1?
Gus
#4 PostAuthor: Gus » Fri Apr 22, 2022 8:09 am
This Kawasaki 21119-1050 IGNITER fits the following models and components:
Kawasaki Motorcycle 1983 KZ750-L3 Ignition
Kawasaki Motorcycle 1982 GPz - KZ750-R1 Ignition
Kawasaki Motorcycle 1981 LTD - KZ750-H2 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1983 LTD - KZ750-H4 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1982 LTD - KZ750-H3 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1980 LTD - KZ750-H1 IGNITION ('81-'83 H2/H3/H4)
Kawasaki Motorcycle 1982 CSR - KZ650-H2 IGNITION ('83 H3)
Kawasaki Motorcycle 1983 CSR - KZ650-H3 IGNITION ('83 H3)
Kawasaki Motorcycle 1981 CSR - KZ650-H1 IGNITION ('83 H3)
This Kawasaki 59026-1019 COIL-PULSING fits the following models and components:
This Kawasaki 21148-1013 ADVANCER,AUTO TIMING fits the following models and components:
Kawasaki Motorcycle 1983 LTD Shaft - KZ750-F1 Ignition
Kawasaki Motorcycle 1983 Spectre - KZ750-N2 Ignition
Kawasaki Motorcycle 1982 Spectre - KZ750-N1 Ignition
Kawasaki Motorcycle 1983 LTD - KZ750-H4 IGNITION ('80 H1)
Kawasaki Motorcycle 1981 LTD - KZ750-H2 IGNITION ('80 H1)
Kawasaki Motorcycle 1980 LTD - KZ750-H1 IGNITION ('80 H1)
Kawasaki Motorcycle 1982 LTD - KZ750-H3 IGNITION ('80 H1)
Kawasaki Motorcycle 1981 KZ750-E2 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1982 KZ750-E3 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1980 KZ750-E1 IGNITION ('80 KZY 50-E1)
Kawasaki Motorcycle 1980 KZ750-E1 IGNITION ('81 -'82 KZ750-E2/E3)
Kawasaki Motorcycle 1982 KZ750-E3 IGNITION ('81 -'82 KZ750-E2/E3)
Kawasaki Motorcycle 1981 KZ750-E2 IGNITION ('81 -'82 KZ750-E2/E3)
"Set the GRINDER on it"
richardwilson45
#5 PostAuthor: richardwilson45 » Fri Apr 22, 2022 6:14 pm
cheers Gus,
will start searching for a set
