Z1000A1 SOLD.
Z1000A1 SOLD.
Kawasaki Z1000A1. In very good unrestored condition. Recent full service and shims checked. Dyna S ignition and Dyna coils fitted, new taper roller head race bearings, new fork oil, new battery, new regulator/ rectifier combined unit,maintained regardless of cost. The seat was replaced when I first bought it almost ten years ago. MOT and tax exempt registered in my name. 15300 miles on the clock which I believe to be correct but I can’t confirm this. The paintwork on the tank has faded on the top and the inside has been coated and is very solid with absolutely no corrosion anywhere. Starts on the button and idles smoothly and no rattles or untoward noises. V&H exhaust which is in very good condition, the wadding on the baffle has been removed and binned as it should be. I have had various nuts bolts and odds and ends re-zinc plated, the original owners handbook is present.I am in sunny Exmouth, UK. Viewing is welcome. £6995.
Re: Z1000A1
Thanks for the positive feedback lads. Malc I will PM you mate.
- warren3200gt
Re: Z1000A1 SOLD.
To a member?
Re: Z1000A1 SOLD.
No, sorry to say I had very little response on here.
