Ultim8pc wrote:PhilMill63 wrote:Thanks for the comments all, I hope to make the bike a bit tidier without ruining the look, its not new but generally in quite good condition. need to sort out the electrics etc, a new loom for a start. Any feedback on Z Power's looms?
Phil
I've done plenty of swaps for those that don't want the cost of refurbishing the original loom.
The repro looms are good enough. However, my advice is that if you're going to do it, replace the main loom, rear light loom and the wiring panel loom at the same time.
Note that the quality of the plugs on the panel can be crap and instead of coloured plastic they are painted. So check before buying.
Thanks, good advice there. I am considering using a few repro bits for now, then I have time to deal with the other bits.
Phil
