Swing Arm
Davehales
Swing Arm
#1 PostAuthor: Davehales » Wed Nov 23, 2022 10:05 am
Ok whats the best swing arm switch, easiest one, ZRX, XJR, other?
Re: Swing Arm
#2 PostAuthor: Z1streetfighter71 » Wed Nov 23, 2022 10:34 am
Davehales wrote:Ok whats the best swing arm switch, easiest one, ZRX, XJR, other?
Depends, are you going with a stock wheel?
needaz1100r
Re: Swing Arm
#3 PostAuthor: needaz1100r » Wed Nov 23, 2022 6:33 pm
Zephyr ZR750, or Bandit 1200.
Mark.
Re: Swing Arm
#4 PostAuthor: ADRIAN H » Thu Nov 24, 2022 9:21 am
What wheel you using - makes life easier if the wheel and swing arm come together.
ZR750, ZRX1200, XJR1300 all work.
Davehales
Re: Swing Arm
#5 PostAuthor: Davehales » Thu Nov 24, 2022 6:51 pm
Looking at putting z650rs wheels, not too wide
Re: Swing Arm
#6 PostAuthor: Z1streetfighter71 » Thu Nov 24, 2022 7:04 pm
The 600rs runs a 160 rear, first thing to do is find out the rear wheel axle size, rear rotor and if anyone else has done it before, save you a load of research. The Zephyr 1100 is a twin shock the runs a 160 tyre. im using one on my Kz1000 as we speak and the gs1100e swingarm is what i have on my Z1000.
Re: Swing Arm
#7 PostAuthor: Z1streetfighter71 » Thu Nov 24, 2022 7:09 pm
Axle size is 14mm, your in luck.
Davehales
Re: Swing Arm
#8 PostAuthor: Davehales » Thu Nov 24, 2022 7:22 pm
Z1streetfighter71 wrote:Axle size is 14mm, your in luck.
:up
Re: Swing Arm
#9 PostAuthor: Al » Fri Nov 25, 2022 12:11 pm
I fitted a ZR 750 ( i think) arm because i didnt want sometimg that looked too new or too technical for what is a 40 year old bike.
Some cutting and welding but relatively straight forward, and a universe away from the original as far as weight and performance goes.
I know a lot of people hate the eccentric adjusters but its a bonus for me to be able to lift or drop the rear ride height by an inch if i feel the need to.
ZR 750.png (124.25 KiB) Viewed 3693 times
Robw
Re: Swing Arm
#10 PostAuthor: Robw » Fri Nov 25, 2022 12:34 pm
I have a zephyr 1100 arm in one bike and zrx 1100 in another. Very easy to fit, just need a sleeve for the spindle bolt.
Rob
Davehales
Re: Swing Arm
#11 PostAuthor: Davehales » Fri Nov 25, 2022 7:16 pm
Robw wrote:I have a zephyr 1100 arm in one bike and zrx 1100 in another. Very easy to fit, just need a sleeve for the spindle bolt.
Rob
:up
