Cylinder Head to Carb inlet rubbers
njwmct
#1 PostAuthor: njwmct » Tue Sep 27, 2022 8:04 pm
Hi Zed Heads,
Has anyone got a ratty old set of inlet rubbers going spare?
I'm going to build a jig to hold my bank of MKII carbs whilst off the bike for setting service fuel levels etc.
Kind regards,
njwmct
Re: Cylinder Head to Carb inlet rubbers
#2 PostAuthor: njwmct » Tue Feb 07, 2023 1:52 pm
Still looking for a ratty old set of inlet rubbers if someone has any going spare? - doesn't matter if they are cracked etc.
HowieD
#3 PostAuthor: HowieD » Tue Feb 07, 2023 3:08 pm
If you can't get hold of any Rubbers, have you thought of a small but of wood and a hole saw ?
I just grab mine (carefully) in a vice on the beefed up idle adjuster
gray
#4 PostAuthor: gray » Tue Feb 07, 2023 7:35 pm
I made a bracket up from an old fridge. Bolt it to the holes in the cable pulley block. then the other end of the bracket is clamped in the vice.That way you're not clamping the carbs at all, Keep it all together with the fuel levels tool.
gray
relisysxx
#5 PostAuthor: relisysxx » Wed Feb 08, 2023 2:00 pm
I've got a spare set, bit hard mind! you are welcome to the if they are any use.
neilbarrett
#6 PostAuthor: neilbarrett » Thu Feb 09, 2023 8:16 pm
Use the ones on ya bike ,
