tank sealant
derek
tank sealant
#1 PostAuthor: derek » Tue Apr 29, 2008 10:49 pm
hi, can anyone recommend a decent tank sealant,
Davy Doherty
#2 PostAuthor: Davy Doherty » Tue Apr 29, 2008 11:03 pm
That's something thats not talked about to much on here for some reason, I wonder why? as i'm sure some of the lads have had to do it, Sorry it's no help but someone will chip in i'm sure..
foreverinthegarage
#3 PostAuthor: foreverinthegarage » Wed Apr 30, 2008 1:32 am
hi
Just had to do my tank. I asked Dave at Z-power and he put me onto another company in Liegh. The product is called Kreem seal and its FANTASTIC, took two days so did it over a week end. First a etcher (left over night) then a cleaner then a sealer. The liner that you end up with is so thin so your tank wont end up twise the as heavy. Before i treated the tank i had many carb problems and leaks from over flows. Now all cured. Cost £35.00
And this will do three tanks.
Regards Mick
Z1000 The King Is Still Alive.
AL MARSHALL
tank sealant
#4 PostAuthor: AL MARSHALL » Wed Apr 30, 2008 7:54 am
1340fxd
#5 PostAuthor: 1340fxd » Wed May 07, 2008 9:51 pm
Hi - I did my tank over last winter and used this:
http://www.frost.co.uk/item_Detail.asp? ... ostSubcat=
Works a treat and is silver metallic colour so you really don't notice it's there when filling the tank
Dear Santa, please can I have...
Geoff Meager
#6 PostAuthor: Geoff Meager » Wed May 07, 2008 10:05 pm
Yes ............ but if the tank has been done a few years ago..will the new sealant & etcher still work ?????
Mine has a brown ( like varnish ) ressidue inside which has started to flake off.
So is it worth me trying to reseal it again ????
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Wed May 07, 2008 11:24 pm
I wonder if the brown shite is actually a build up of petrol varnish?
Ralph Ferrand
Steve S
#8 PostAuthor: Steve S » Thu May 08, 2008 8:29 am
Exactly, so how best do we look after our tanks? is it a necessity to seal them up just because they are old or can we clean them out and remove the gum.
I guess if they are rusting then sealing is a good idea and will protect your tank and fuel system from clogging,but should we seal them before we get to that point :?:
bedlow1
#9 PostAuthor: bedlow1 » Thu May 08, 2008 4:42 pm
one of my tanks has light brown rust and i too recon that this is working into the carbs so something needs to be done.
my concern is that i dont want chemicals to ruin the paintwork on the tank which is in good condition, any tips
1972 Z1 Euro Spec
1975 Z1B UK Bike
Geoff Meager
#10 PostAuthor: Geoff Meager » Fri May 09, 2008 8:53 pm
Was chatting to the geezer who sorted out my bike.. about the tank sealant question ....he recommends a teaspoon of oil in the tank every-time you fill up..
suppose it works on the same principle as Diesel (but not so oily) as a Diesel tank don't suffer the same corrosion as a Petrol one
anyone heard this before :?:
z1bnackerkwacker
#11 PostAuthor: z1bnackerkwacker » Sat Jun 14, 2008 11:19 pm
Geoff Meager wrote:Mine has a brown ( like varnish ) ressidue inside which has started to flake off.
Mine had same brown varnish, above kit "MARINE CLEAN part of kit cleaned" it (use nuts & bolts inside if really rough), no prob', followed instructions, plenty of rinses and hair dryer in cap and dry thoroughly (must thank the missus), did mine approx 3 years ago and still fine, Remember to keep old fluid can be used again, I poured mine away without thinking :roll:
You could do several tanks with the kit..
Users browsing this forum: Bing [Bot] and 40 guests
