wanted carbs
Re: wanted
I've just finished restoring a set of Z900A4/A5 carbs, which I had lying around. They've been vapour blasted and ultrasonic cleaned. New jets from motocarb. All bits have been re-zinc plated with new return spring, gaskets and the two feed link connector pipes.
Also includes a new carb connector plate, from a batch I made recently.
Are these of any interest?
						- Z1streetfighter71
 - ZedHead
Re: wanted carbs
Do you sell the connector plates on their own? that look a tasty bit of kit.
Re: wanted carbs
Nice job Mike.
						Re: wanted carbs
Z1streetfighter71 wrote:Do you sell the connector plates on their own? that look a tasty bit of kit.
Yes, they're BZP steel. £12 + postage (£3 tracked in UK)
						Re: wanted carbs
chrisNI wrote:Nice job Mike.
Thanks Chris. Was bored waiting for bits to arrive so used the time renovating these. Plus I then had to make the carb connection plate as I couldn't find any in the UK.
