z1000a1 rear footrest bracket
Peteypops23
#1 PostAuthor: Peteypops23 » Thu Jul 20, 2023 4:05 pm
Hi folks,
I'm after a rear footrest bracket for an A1/2 if anyone has one hiding in a box in the shed? Condition unimportant as long as it's in one piece :D
Many thanks,
Re: z1000a1 rear footrest bracket
#2 PostAuthor: warren3200gt » Thu Jul 20, 2023 4:15 pm
Visually it looks the same as a 650 one. If it is I have several.
Check the part numbers and if the same let me know.
Peteypops23
#3 PostAuthor: Peteypops23 » Thu Jul 20, 2023 5:33 pm
Will do Warren, thank you.
Peteypops23
#4 PostAuthor: Peteypops23 » Thu Jul 20, 2023 7:19 pm
warren3200gt wrote:Visually it looks the same as a 650 one. If it is I have several.
The a1 part number is 34036-001 and the z650 is 34036-002. They do look, as you say, visually similar. I'll measure the existing one and compare, if you don't mind?
Thanks,
#5 PostAuthor: warren3200gt » Thu Jul 20, 2023 7:43 pm
:up
Peteypops23
#6 PostAuthor: Peteypops23 » Thu Jul 20, 2023 8:26 pm
So....length is 59mm, width 28mm.
Flat top section where pin fits through is 23mm, leaving 36mm on the slopes.
Distance between bolt hole and locating hole is 15mm centre to centre.
If you don't mind checking a 650 one when you've got time Warren, that would be great. No rush!
Thank you.
#7 PostAuthor: warren3200gt » Thu Jul 20, 2023 8:31 pm
Do a sketch with dims on and I'll dig one out tomorrow and compare.
I want to see how artistic you are :lol:
compo z1r
#8 PostAuthor: compo z1r » Thu Jul 20, 2023 8:47 pm
All same these 2 of a mk2 loads on eBay
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
#9 PostAuthor: warren3200gt » Fri Jul 21, 2023 1:58 pm
Dimensions as per your post. Ping me your address and I'll get it out to you.
Peteypops23
#10 PostAuthor: Peteypops23 » Fri Jul 21, 2023 2:47 pm
Champion :D
steve-g
#11 PostAuthor: steve-g » Fri Jul 21, 2023 3:18 pm
The smaller hole on 650 is above the large one, on the 1000 its the other way round.
#12 PostAuthor: warren3200gt » Fri Jul 21, 2023 3:28 pm
steve-g wrote:The smaller hole on 650 is above the large one, on the 1000 its the other way round.
Good spot!
Guess ebay it is then Pete.
Peteypops23
#13 PostAuthor: Peteypops23 » Fri Jul 21, 2023 5:33 pm
Bu@@er......didn't even notice that meself
Thanks for the trouble guys, much appreciated.
Pete!
compo z1r
#14 PostAuthor: compo z1r » Fri Jul 21, 2023 8:13 pm
hang about the small hole above the large one is z650 ? as pete's picture ? posted ? but 1000 is below large hole aint that what he wants 1000 a1-2 ? as mine and warren's pic ?
#15 PostAuthor: warren3200gt » Fri Jul 21, 2023 9:34 pm
No Pete wants large closest to edge as per first picture in thread so opposite to ours.
