Out for a run before the rain came
- paul doran
- Z1streetfighter71
Re: Out for a run before the rain came
Looking good Paul, is that a MORIWAKI Exhaust?
- paul doran
Yes I beleive it is
Got home before the heavy rain started thankfully
Hi Paul
nice Z1000A2 you have there, congratulations!
Let's hope the summer becomes a summer instead of an autumn...
- paul doran
Thanks Philippe
I hope to modify it a bit I have these I might fit or a set of genuine 1000H wheels
- paul doran
Hi Paul
I would advise you to take the H wheels. They're original Kawasaki although they need a refurb. Just keep in mind that you'll need another spacer for the rear wheel.
- paul doran
Philippe do You have the dimensions of that spacer please
Hi Paul
the spacer between the hub and the rear brake caliper must be 31 mm long if you use the alloy wheel.
The spacer of the spoke wheel (original) is shorter.
Users browsing this forum: jonathan and 2 guests
