Hi Folks
I have a friend in South Africa with a Z1300 from 1981. It’s been modified a little and he’d like to OEM it a bit more. Would anyone have indicators, mirrors, silencers, a rear wheel and a rear mudguard available? If not, are there pattern items or other options available?
Many thanks Jonathan
Z1300 parts wanted
Re: Z1300 parts wanted
Many thanks, will have a look. He’s on a budget so I was thinking secondhand, is there much of a market?
I don't have any Z13 parts but I am intrigued by the back wheel in your picture. Do you have any pictures showing a close up of what it is?
Cheers, Rob
Cheers, Rob
Z1000ST
Z650b
Guzzi 750 Ambassador
Guzzi 1100i endruance racer
Guzzi 1400 Eldorado sidecar hack
Z1000ST sleeper
Z650b
Z1000ST sleeper
Is that any clearer? I believe it’s a standard wheel but someone has widened it by adding an aluminium section each side of the spokes. Very neat job, very well executed and a low profile tyre added but it’s not what the owner wants!
PM sent
Z1000ST
Z650b
Z1000ST sleeper
Z650b
Z1000ST sleeper
Further to the above…. Does anyone know if the 1300 shared indicators with any other Kwacker?
I believe the indicators are exclusive to the 1300, they are rare items, like most parts these days, nos are even more rare, if you can get them.
Thanks for the reply David, much appreciated. Is there a pattern available or even one that’s very similar? Basically he has those mini indicators and if unable to get OEM then anything similar is better!
Users browsing this forum: chrisu and 62 guests
