Hi, anyone fitted a set of Paolo Tarozzi rear sets on a Z900-A4?
Very basic part’s diagram supplied, but no fitting instructions. I’m happy enough with the gear linkage side…but a bit confused with the rear brake setup (drum)…it’s the ‘return spring’ linkage and actuator rod fitting that’s got me stumped. (Standard existing setup in first photo).
I’ve emailed the company, but no reply….if anyone has fitted these and could send me some photos of the rear brake setup that’d be great. Cheers.
Paolo Tarozzi rearsets on a Z900-A4
- Paul Whitehouse
If it's too loud....too bad.
Re: Paolo Tarozzi rearsets on a Z900-A4
I am sure you have to use the original Return spring on the new linkage
