Vendetta and his shaft addiction
Sifu
Re: Vendetta and his shaft addiction
#16 PostAuthor: Sifu » Wed Aug 14, 2024 5:05 pm
r3sc wrote:Welcome back! Nothing wrong with a good shaftie! Although I have my fix from a different stable that’s a bit more on the dark side! :D
Very nice indeed I’ve got a E really nice G mate
Vendetta761
#17 PostAuthor: Vendetta761 » Mon May 19, 2025 11:40 am
So, back again, life just gets in the way, bereavement, financial issues and more life changes meant I had to sell the 2 x Z1000 Sts I had, ( one to a club member luckily).
I never should have sold my original rebuild but divorce required it, won't be doing that again.
However, when I did sell , I asked the buyer to give me 1st refusal if he ever sold as I put my heart and soul into that rebuild and , I got a call recently saying he was selling up. No money but a credit card transfer came to the rescue, ( let's hope I can pay that off soonest) and I picked her up at the weekend.
New owner had done some changes, new paint, carb refresh, seat cover and a bikini fairing that I am not sure I like, also losing the original clocks for a combined speedo /rev counter thing ( not sure I like this either).
Has some issues, new battery required, has only done 200 miles since i sold her and she has been sitting for a while so needs a brake fluid flush and maybe rebuild, will see. The choke lever is stuck, seems one or more of the choke plungers on the carb may be stuck, will need to remove the carbs to investigate this, any ideas anyone?
Anyway , here are some pics of her, different from when I sold her but still the same beautiful bike underneath.
1980 Z1000 E1- ST , 1980 Yamaha XT 250 3Y3 , 1979 Moto Guzzi G5 special , 2000 V11 special, 2009 XT660 X
#18 PostAuthor: Z1streetfighter71 » Mon May 19, 2025 11:43 am
Thats a class looking bike sir. Great to have her back again. :vcool
Vendetta761
#19 PostAuthor: Vendetta761 » Fri Aug 15, 2025 4:52 pm
So back again, hope everyone not too hot, finally got some time in the garage.
Stuck choke sorted, 2 of 4 plungers were seized solid so a long soak in some diesel sorted them.
Got a new Motobatt battery and all electrics seemed to work fine.
Made up a new ali bracket for electronic speedo rev thing which I do not really like the look of it now mounts centrally to the yokes and sits a bit lower.
Fairing off, anyone want a fairing ?
New fuel and run up and she is smooth as silk, lovely. A run up to the airport and back and a horrible rattle from front left calliper ,mmmmm .
Pulled over and left calliper defo a bit more jiggle room than right , assume:
A. the rubber bush things on the bolts that hold the caliber to the mounting bracket allowing "free floating" are worn and need replacing ?
B. The disc on one side is not seating properly as previous owner had wheels powder coated and it may not be a flat mounting surface where disc bolts to hub.?
C. Disc warped ?
Only say this as it seems to quite when turning right but rattle is loud and constant when straight or turning left.
Any previous history of similar from anyone ( Philipe ?) or ideas, suggestions, wisdom before I strip calibers and rebuild afresh ?
