Rajay 370 F40 turbo up for grabs. Original fitment to all TC's.
Fully rebuilt by myself with NOS bearing, NOS ceramic seal, F-flow turbine with absolutely perfect shaft, superb chrome on the 4LAC F-flow turbine housing. F-flow compressor wheel & housing with the original Rajay factory tag. Oil feed input moved to the correct position (at the top) with extended oil feed hose and new fittings and new oil drain elbow.
Zero play, ready to run. £1000
Will ship worldwide.
Rajay 370 F40 turbocharger
