pickup housing
sockpuppet
pickup housing
#1 PostAuthor: sockpuppet » Tue Jan 07, 2025 6:50 pm
Hello
I am looking for a replacement pickup housing for my Gpz1100B2,
Does anyone know what others are the same ? -- ( z1000j, unitrak etc ? )
Any info greatly appreciated
Mick
Robw
Re: pickup housing
#2 PostAuthor: Robw » Tue Jan 07, 2025 9:50 pm
If it's this you are after, then it's specific to the b1 or b2, CMSL have two for sale.
Rob
Robw
Re: pickup housing
#3 PostAuthor: Robw » Tue Jan 07, 2025 10:03 pm
Cover, Engine, Rh, F.bla Kz1100b2 Gpz 1982 Usa Canada
fits:
Kawasaki
product number:
140251279
CMS product number:
KA0004.7881
GBP 222.04 ,incl. 20% VAT
sockpuppet
Re: pickup housing
#4 PostAuthor: sockpuppet » Wed Jan 08, 2025 6:19 pm
Hi Rob
Thanks very much for taking the trouble to reply with that info ,
Sorry to say my post was a badly worded and a bit misleading,
What i really would like to know is are they `Physically` the same ,
ie could i use a z1000j or z1100 casing
as there are lots about would be better for me because they are alloy finish not black and would be less work to make match the rest of my outer cases that are all polished alloy.
Very sorry for misleading you and i greatly appreciate you taking the time to help .
Regards
Mick
Robw
Re: pickup housing
#5 PostAuthor: Robw » Wed Jan 08, 2025 7:35 pm
They do both fit, however it depends what electronics you want to put in there, definitely dyna s doesn't fit as the b1/2 case is deeper.
However, looking at the part numbers for the standard pickups,they are the same across all of the later 1000 and 1100 models.
Rob
sockpuppet
Re: pickup housing
#6 PostAuthor: sockpuppet » Thu Jan 09, 2025 8:44 pm
Thanks for that useful info,
I was hoping the gpz one was just a black version of the J one and could save myself a bit of polishing !.
Mine is a bit damaged inside so cover is only held by one bolt,.
I will look out for a gpz one but theres no rush i was just thinking I'd finally sort it out after over 30+ years like that !.
Many thanks
Mick
