Decals
Decals
Quick bit of advice from you knowledgeable chaps,when to put the decals on.This is going on a zephyr 1100 ( wire wheels ) choices are after base coat before lacquer,couple of coats of lacquer then apply decals with a couple of lacquer after or completely finish tank then apply
- warren3200gt
Re: Decals
Couple of laquer then decals then couple more laquer.
- Z1streetfighter71
- ZedHead
Re: Decals
Dont go crazy with to many clear coats over your base, quick pass and then one "wet coat" if you are using a room temp clear allow at least a week before the final 2 coats over the decals. To many clear coats can muddy the base coat.
Users browsing this forum: Bing [Bot] and 33 guests
