Not an ideal time of the year, but been prepping and undercoating the bodywork for my own Z650/GPz750 project.. outside.. but needs must. The tank was in good shape, except for a dent by the badge. I used a crude but effective method of removing the dent. Bend a thick alloy bar, held it in the vice, then with the bar passed through the filler hole, the tank was hammered (carefully) against the bar to push out the dent. The result wasn't perfect, but a lot better than it was, with a bit of filler, looked as good as new, well almost.
The bike will be painted in Candy apple blue, but haven't made my mind up yet what kind of pinstripes/graphics its going to have. The wheels are gold, so leaning to gold pinstripes or something like that. I may leave the paint as is, and save a lot of time and effort. I see pinstripe kits on Ebay for the various 650 models, but none really appeal.
The candy paint I'm using is just rattle can 1K, but the clear top coat is 2K. That means that once the colour coat is done, it then needs to be left untouched for several weeks, to allow the 1K pint to 'gas off'. As 2K paint is impervious to petrol, but also to the gas emitted by the 1K paint beneath. If you don't wait long enough, this 'gassing off' can cause bubble and delamination of the clear top coat.
