As long as you aint colour-blind its a piece of cake
the only hard thing with it is to:-
Guesstimate the amount of wire required + sleeving and connectors.
once you add the 3rd wire to the loom tape it up at every "hand width" as you add the wires tape them up too.(keeps it neat)
Dont forget the "drops" eg. the Earth(black/yellow) and regulated feed(brown) have the most drops.(now practise soldering skills)
use non adhesive tape on loom.
Leave the tails long.(you dont want to fluff 2nd fix)
When wiring to the lamp/switch gear allow for the turn of steering.
If you wanna use block connectors remember............
Well.i stick to bullets all the time.
Lawdy another thesis
On the current ZeD the wiring was
Ripped the lot out and start again. Halfway there on first fix
