Hi, Just brought Z1000A1 & found the brake fault light warning on the display not working. Have done the usual checks & tests & found that the fault light switch relay ( the one under the tank connected to the loom with a 3 pin plug) has failed. Does anyone have one for sale or know where I might get one.
Many thanks in advance for your help
Z1000A1 REAR BRAKE LIGHT FAULT SWITCH/RELAY WANTED
1976 Yamaha FS1E
1976 Kawasaki Z1000A1
2020 Yamaha Tracer 900 GT
Re: Z1000A1 REAR BRAKE LIGHT FAULT SWITCH/RELAY WANTED
Contact Phil @ ZPower
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Dobby7 wrote:Hi, Just brought Z1000A1 & found the brake fault light warning on the display not working. Have done the usual checks & tests & found that the fault light switch relay ( the one under the tank connected to the loom with a 3 pin plug) has failed. Does anyone have one for sale or know where I might get one.
Pretty sure I have a few NOS ones I'd be happy to sell.
Many thanks to you both for your quick replies. I have managed to locate 1 now. Many thanks again.
1976 Yamaha FS1E
Ultim8pc wrote:Dobby7 wrote:Hi, Just brought Z1000A1 & found the brake fault light warning on the display not working. Have done the usual checks & tests & found that the fault light switch relay ( the one under the tank connected to the loom with a 3 pin plug) has failed. Does anyone have one for sale or know where I might get one.
Hi, please could you confirm the cost & postage to RG41 5AJ for a new rear brake fault light switch please. Z1000a1
Many thanks
1976 Yamaha FS1E
