Brakes
Brakes
So ive got zrx1200 daeg forks on my gpz1100 i got a nice top yoke made to take the ignition and clocks now im onto wheels and brakes,ive got zrx1200 wheels new discs now im looking for calipers preferably Brembo but it turns out the mount holes are 63mm and there are very little brakes out there ! Would you open out the mount holes to take 65mm brake as there is a wide selection?
- warren3200gt
Re: Brakes
Make adapter plates
Re: Brakes
Agreed - bit dodgy to oval out the holes to fit, you'll create a weak spot and then one day , on heavy braking ,the calliper will come adrift just when you need it to be rock solid
gray
Re: Brakes
warren3200gt wrote:Make adapter plates
Do you know anyone that makes adapters?
- warren3200gt
Re: Brakes
Pretty much any engineering workshop can make them if you can't yourself. Just need to give them drawings.
Re: Brakes
Rapide Engineering , Trinty Gask , Auchterarder . 01764 683853 . They made the plates for the brakes on the front of our 1000R2 , std forks , Eliminator wheel , 320mm floating discs and Nissin 4 pot calipers . I am taking the front end from my klr650 up over the winter to get a plate made to for a brake upgrade .
fer
fer
Re: Brakes
FER wrote:Rapide Engineering , Trinty Gask , Auchterarder . 01764 683853 . They made the plates for the brakes on the front of our 1000R2 , std forks , Eliminator wheel , 320mm floating discs and Nissin 4 pot calipers . I am taking the front end from my klr650 up over the winter to get a plate made to for a brake upgrade .
fer
Cheers not too far away either
- Z1streetfighter71
- ZedHead
- Z1streetfighter71
- ZedHead
Re: Brakes
Not to be pedantic but why? the zrx1200 calipers are more than adequate and the Brembo set up is around £722.00
https://www.ebay.co.uk/itm/134743109419
Re: Brakes
Z1streetfighter71 wrote:Not to be pedantic but why? the zrx1200 calipers are more than adequate and the Brembo set up is around £722.00
That set up doesn’t fit the forks i have ,and bike torque don’t do adapters for my forks , i got brembo callipers for half that price from japan .
Next question is do i need the brake disc gaskets? I’ve never seen them before bit the zrx1200 has them.
Re: Brakes
stusco wrote:Z1streetfighter71 wrote:Not to be pedantic but why? the zrx1200 calipers are more than adequate and the Brembo set up is around £722.00
I don’t like tokio callipers they are prone to seized pistons
Re: Brakes
Hi Nissin 4 pots from gsxrs etc are brilliant and bolt straight on.
Alternatively you couldgo radial as Hel do brackets to convert to radial.
Re: Brakes
My forks are zrx1200 daeg they are different from the uk zrx1200 forks
Re: Brakes
fer
Dropped my front end off on Monday
