gpz1100 unitrak mudguard
Can anyone tell me if the front mudguard on the GPZ11 uni is ABS plastic i had always thought mine was original and now someone has put doubt in my mind.. it has a bracing piece of metal in the middle section if that makes sense
Re: gpz1100 unitrak mudguard
I can't say if its ABS Plastic, but it is plastic and you are correct there is a steel brace that you sandwich the mud guard between the forks and the brace. I can take pictures if you need them.
Thank you Mark i thought it was plastic...... someone asked if mine was aftermarket but i beleived that it was a original and you have confirmed
