1979 Z1 classic bosch fuel injection
actionman
#1 PostAuthor: actionman » Fri Jun 06, 2008 4:08 pm
hi,could anybody shine a little light on a problem my mate has.His classic is a bit of a bugger on start-up,coughs n splutters until warm....ive had it suggested to me that the heat sensor is at fault,not telling the engine its warm enough?This sounds about right as when its heated-up it runs fine.
I havnt had a good look at the bike,so am asking where the heat sensor is located...and are these still avilable...if so where?Thanks for your help. :)
Pasc
#2 PostAuthor: Pasc » Fri Jun 06, 2008 4:28 pm
If its anything like the other fuel injected kwaks the engine temp sensor will be tapped into the cylinder head between 1 and 4 inlet ports. These can suffer from corrosion on the connector and also on the threads of the temp sensor so clean it up and refit. :wink:
actionman
#3 PostAuthor: actionman » Fri Jun 06, 2008 4:33 pm
Thanks Pasc,will have a good look over the weekend.cheers
Pasc
#4 PostAuthor: Pasc » Fri Jun 06, 2008 4:35 pm
Sorry actionman, that last post should read "between No1 and 2 inlet ports.
Users browsing this forum: Bing [Bot] and 35 guests
