Hi guys eventually I will be building a Z900 to go with the Z1000 (Lily Grace - Depending), however after checking all the boxes, 5 yrs later it looks like there is no crank. There is one on ebay for a Z1000A1 / A2 are they the same??
PJ
Crank
phil churchett
The 900 cranks are 'webbed' whereas the Z1000 cranks are full flywheel.
If you're using standard height pistons you're ok with either.
If like me you're using taller 'turbo' pistons then you have to use the webbed crank to stop the pistons smacking into the crank as you approach BDC.
