Drive chain adjustment - advice
- Dark Skies
How do you guys adjust your chains? The manual reckons to put the bike on the centre stand and aim for 30 - 35 mm play in the middle of the bottom run of the chain. However, with the bike off the stand and me sitting on it that chain gets wicked tight - like a guitar string.
It's a new chain and sprocket set so there are no tight spots to deal with.
When I do my Triumph Speed Triple the chain is adjusted on the side stand to 35 - 40 mm play. When I'm sitting on it the slack is taken up but it doesn't feel anything near as tight as the Kwak because it was adjusted with most of the weight of the bike loaded beforehand.
I've got the JMC arm on it now - so I have to be careful to strike the right balance - don't want to be sawing through the alloy - and due to the higher profile of the arm I've less clearance over the stock item to play with.
KZ1000-M1 CSR
I think you've answered your conundrum yourself....
The improtant bit is to have correct tension whilst on the bike...
So you'll have to try it a few times and get someone to check with you on it, or get a similar stature person to sit on the bike whilst you check
- ZedHead
- Dark Skies
- RALPHARAMA
I guess a paddock stand might be a good route to go. Praps stick a sack o taters on the seat
Ralph Ferrand
- Dark Skies
vduk wrote:I guess a paddock stand might be a good route to go. Praps stick a sack o taters on the seat
Great minds think alike- even as I type the bike is propped up on my trusty universal paddock stand. It'll go some way to getting a more accurate reading - then I'll see what the take up is with my strapping six foot frame and beer gut on the bike..
I've also noticed the sprocket is smaller than standard - 34 teeth instead of 39 oem. I worked out (using an online gear ratio tool) that it's theoretically capable of providing a 18 mph gain at full chat. Weighing up the loss of that small gain against the chain sawing through the middle of the JMC I've opted to put on the standard rear sprocket - raising the chain run to a less risky height - the diameter of the sprocket being some 20 mm greater than the one that was on it.
KZ1000-M1 CSR
A rubbing pad fixed to the top of the arm will stop the chain cutting through.
If you have all three axle centres in line and 3/4" chain movement at the tightest point that is the correct chain tension. When you have done that put the shocks back on and measure it on side stand / centre stand to see how much movement you have there and write that down for future use.
- Dark Skies
Rich wrote:A rubbing pad fixed to the top of the arm will stop the chain cutting through.
Good stuff. Thanks. Know anywhere where I can get a rubbing strip?
KZ1000-M1 CSR
- Dark Skies
