Might sound like a stupid question but how do i tell what size my set of mikuni flatslides are?
I cant see anything on them to suggest a size or model number. Is it just a simple case of measuring across the inside diameter of the main venturi? (34mm if that is the case).
Would these be big enough to run my modded engine? 1170 bore, gas flowed head, .395 lift cams etc......
Mikuni Flatslides sizing
- big green bus
The only things stamped on side is G6 31 on 1 side and 27a 02 on the other.
They are 34mm inside diameter on inlet side so looks like I might be in the market for a set of 36mm! Anyone fancy a part exchange?.
Final question.....
carbs 1 &2 and 3 &4 have a plastic hose connector between the main carb bodies (not the fuel inlet just above float chambers) - should these have a hose between them to balance or are they some kind of vacuum return?
Sorry to be a thicky but these have been lying around for longer than I care to remember.....
Final question.....
- big green bus
