Z650 wiring loom
Z650 wiring loom
Hi there
Have got to the stage with the rebuild of my '79 Z650 where we are about to send the frame for powder coating, and then it's the big push to start putting it all back together again.
Thing is, we need a new wiring loom really. Does anyone know where we can source one and how much it will cost?
Hevs
Hevs
Bird on a Bike
- RALPHARAMA
Have you tried Z Power?
Ralph Ferrand
Depends how bad yours is... If all the plugs are there and there aren't too many broken wires and butchery you should be able to fix it up. You can buy proper non sticky loom tape, and white spirit removes road grime, dirt, and adhesive from old bodged sticky tape like you wouldn't believe. A clean, new tape where needed and nice heat shrinked repairs it mightn't be too bad.
Vehicle Wiring Components will sell you all the bits including block connectors to make one:
http://www.vehicle-wiring-products.eu/V ... mepage.php
A lot better than buying a second hand one.
- Dark Skies
I'd make a new one if I were you. It's actually pretty easy to do. Just strip off all the old loom tape, peg it taut to a board (so you get all the lengths right) and then make a copy like for like. Remove and clean all the original plastic blocks using electrical cleaner and re-use. Refit using wire and connectors from http://www.vehicle-wiring-products.eu/V ... mepage.php
Wrap it up using loom tape (not insulating tape) and you're done. It'd only take a day and modern wire is less bulky than the original so you'll get a neater fit.
KZ1000-M1 CSR
J Browse, over in Wrexham (advertises in CMM) has them from italian z650s - much better nick than UK ones. They aren't cheap though - £75. I bought one as mine was horrible and I'd been through all the usual routes already, and short of having one made for me this was my only remaining option, and it is in really good condition. Light clean, and it looks as new.
Currently restoring a 78 z650
Bruce Sexton
This new site advertising in our for sale section lists a NOS mid section. Don't know them from adam but maybe worth a look.
http://www.vintagecyclepart.com/
Bruce
Bruce
Bruce Sexton wrote:This new site advertising in our for sale section lists a NOS mid section. Don't know them from adam but maybe worth a look.
Bruce
I had a look, and I'm not sure what the photo is but it isn't the main wiring harness - still, at the price it might be worth a stab...
