how do you remove a needle jet?
Taffus
#1 PostAuthor: Taffus » Thu Sep 11, 2008 5:05 pm
Hi
Stripping a set of BS34 carbs. Does anyone know how to remove the needle jet?
Regards Mark
#2 PostAuthor: Pigford » Thu Sep 11, 2008 5:29 pm
Taffus, remove the main jet, then it should push out! Some carbs they screw in, but the Climer manual look like it is an interference fit :|
Taffus
#3 PostAuthor: Taffus » Thu Sep 11, 2008 6:02 pm
Pigford wrote:Taffus, remove the main jet, then it should push out! Some carbs they screw in, but the Climer manual look like it is an interference fit :|
Mark
when you are jetting carbs , do you change the needle jet?
#4 PostAuthor: Pigford » Thu Sep 11, 2008 6:15 pm
NO....... just mains...
The needle will control when & how the main kicks in from about 1/4 - 1/2 throttle (approx). They come in different tapers & lengths :??
Users browsing this forum: kev edwards and 47 guests
