z900 a4 blows main fuse
morgan
#1 PostAuthor: morgan » Tue Sep 16, 2008 8:57 am
Hi, Trying my hand at restoring a z900 A4. It runs well but blows the main fuse after a couple of miles. Any ideas?? thanks
tlc
#2 PostAuthor: tlc » Tue Sep 16, 2008 9:13 am
Start at the beginning ?
phil churchett
#3 PostAuthor: phil churchett » Tue Sep 16, 2008 9:23 am
tailiftchris wrote:Start at the beginning ?
Like Chris says, we will need a bit more info.
Was it a runner when you bought it? If so, is this a recent problem?
If it was a non-runner, why?
Are you riding it with lights on, if so does it blow bulbs?
I can lend you a colour wiring diagram if it's any help?
#4 PostAuthor: Pigford » Tue Sep 16, 2008 11:12 am
If it blows the fuse after a few miles...............
#1 could be loose wiring (connecter/joint, etc)....
#2 could be bare wire shorting....
#3 could be reg/rectifier Donald Ducked....
morgan
#5 PostAuthor: morgan » Wed Sep 17, 2008 7:48 am
Thanks, was wondering if it was a common problem with an easy solution...guess not. Not a fan of electrics...will check connections and if no good find a man who knows these things!!
Users browsing this forum: Google [Bot] and 43 guests
