Shocks
mikey
Shocks
#1 PostAuthor: mikey » Sat Sep 13, 2008 11:41 am
Just stripped my marazochi shocks to refurbish them chrome the springs etc renew the seals, when i rebuild what weight and quantity of oil do they take.
tlc
#2 PostAuthor: tlc » Sat Sep 13, 2008 4:24 pm
Mikey. I remember doing my set on the kettle.
The oil level is to the top when you stand the shocks in a certain position, so it runs over the reservoir. (I think it may be so the reservoir is at 45 degrees)
As for weight of oil, that is a variable like the shims in the valve. I had 10 weight hydraulic oil to hand so used that. You could use 5, 10, or even 15 weight so that gives you some scope for trial and error.
But I think the handbook said 5 weight.
mikey
#3 PostAuthor: mikey » Sat Sep 13, 2008 7:44 pm
Ok thanks chris, dont know if it makes a difference but these shocks are for my MK2 not my A2 doubt it makes a difference.
mikey
#4 PostAuthor: mikey » Tue Sep 16, 2008 8:00 pm
Thanks for the explanation over the phone tonight chris very helpful, its help like this is what makes the club what it is, thanks again chris.
Taffus
#5 PostAuthor: Taffus » Wed Sep 17, 2008 7:27 am
Hi
Does anyone know where i can get the seal etc for these shocks? :?:
tlc
#6 PostAuthor: tlc » Wed Sep 17, 2008 1:36 pm
I went to a classic Laverda specialist for my bits. I got seals and shims from them for very reasonable cost.
Unfortunately they are now gone but it shouldn`t be too hard to find another suplier.
phil churchett
#7 PostAuthor: phil churchett » Wed Sep 17, 2008 3:09 pm
You could try www.slaterlaverda.com
Users browsing this forum: Google [Bot] and 43 guests
